-   MINI Discussion Forum (http://forums.pelicanparts.com/mini-discussion-forum/)
-   -   Question on Crankshaft Pulley Replacement (http://forums.pelicanparts.com/mini-discussion-forum/884064-question-crankshaft-pulley-replacement.html)
Bill (guest) 09-22-2015 07:11 AM
I just did this repair on a 2003 Mini. I purchased an aftermarket pulley which looked just like the OEM. I had to use the puller to remove the old one but the new one I was able to pretty much press onto the shaft by hand. Maybe the pulley was bored incorrectly? Im only concerned now because with that done and a new belt I have a high pitch squeal which sounds like a belt, but now makes me worry that the crankshaft is slipping inside of the pulley.
This post was auto-generated based upon a question asked on our tech article page here:
Nick at Pelican Parts 09-22-2015 07:11 AM
Spray a small amount of water on the belt, does the noise go away?
- Nick
