-   MINI Discussion Forum (http://forums.pelicanparts.com/mini-discussion-forum/)
-   -   Question on Clutch Replacement (http://forums.pelicanparts.com/mini-discussion-forum/884067-question-clutch-replacement.html)
Dr. (guest) 09-22-2015 08:12 AM
My 2005 Mini Cooper S with 87,000 non hot roded miles has a clutch petal on the floor. I replaced the Master & Slave Cylinder and bleed with a pressure bleeder. No help! Exchanged both units with other new units. Same problem! The clutch petal has no fictions in it's movements top to bottom. Why or what?
This post was auto-generated based upon a question asked on our tech article page here:
Nick at Pelican Parts 09-22-2015 08:12 AM
Does the clutch fork have resistance when pressed by hand?
- Nick
Dave at Pelican Parts 09-22-2015 10:44 AM
How certain are you that you got all of the air out of the system? When we see brakes with this type of behavior, the reason is almost always that there is still air in the system.
--DD
