-   MINI Discussion Forum (http://forums.pelicanparts.com/mini-discussion-forum/)
-   -   Question on Coolant Expansion Tank Replacement (http://forums.pelicanparts.com/mini-discussion-forum/886426-question-coolant-expansion-tank-replacement.html)
Ferd (guest) 10-09-2015 01:31 PM
Hello. Do you have the part # of the hose on the bottom of the expansion tank? When doing an oil change, removing the filter, noticed it was leaking there. It losses coolant over a two week period and there are no other visible leaks nor coolant in the engine.
2008 Mini Cooper S 6 speed.
Thank you.
This post was auto-generated based upon a question asked on our tech article page here:
Nick at Pelican Parts 10-09-2015 01:31 PM
I’m not the best with part numbers.
Give our parts specialists a call at 1-888-280-7799. They can figure out what part or repair kit you need.
- Nick
