-   MINI Discussion Forum (http://forums.pelicanparts.com/mini-discussion-forum/)
-   -   Question on Clutch Master and Slave Cylinder Replacement (http://forums.pelicanparts.com/mini-discussion-forum/886427-question-clutch-master-slave-cylinder-replacement.html)
G-T (guest) 10-09-2015 01:31 PM
If the clutch pedal becomes rough during driving with hot engine and in summer days and stay rough even depressing it with engine off but with no brake fluid loss it's a hydraulic problem slave-master cylinders, a clutch kit mechanical issue or simply the pedal bushing?
This post was auto-generated based upon a question asked on our tech article page here:
Nick at Pelican Parts 10-09-2015 01:31 PM
I would assume it is a mechanical issue with the clutch itself.
- Nick
