-   MINI Discussion Forum (http://forums.pelicanparts.com/mini-discussion-forum/)
-   -   Question on Crankshaft Seal Replacement (http://forums.pelicanparts.com/mini-discussion-forum/887176-question-crankshaft-seal-replacement.html)
Brian (guest) 10-15-2015 02:48 AM
Hi,
How much is the tool for installing the crankshaft seal?
I just found out that was where the leak was from on my engine after the dealer told me the casm cover gasket, oil pan gasket and the VANOS solenoid O-ring were leaking. I changed all of those things and the timing chain tensioner while I was in there. I had the well liner out. That's how I saw where the leak was from. Do you sell the fasteners for that? The plastic ones.
This post was auto-generated based upon a question asked on our tech article page here:
Nick at Pelican Parts 10-15-2015 02:48 AM
We can get you what you need. I recall the tool being a little $100.00
I’m not the best with part numbers.
Give our parts specialists a call at 1-888-280-7799. They can figure out what part or repair kit you need.
- Nick
