-   MINI Discussion Forum (http://forums.pelicanparts.com/mini-discussion-forum/)
-   -   Question on Shift Cable Replacement (http://forums.pelicanparts.com/mini-discussion-forum/889874-question-shift-cable-replacement.html)
imind (guest) 11-04-2015 05:10 PM
Thank you Nick for your reply. We actually disassemble the whole thing as per this article; then unscrued the "shifter box" and took it out - it was needed to remove the center console to acomplish this. We opened the box. It needs to be opened carefully since there are a couple of springs that will immediately jump all over. Inside the box, there's a hard plastic, conic shaped, piece that allows the positioning and fwd-bwd stepping of the shifter. It was broken at several points, like smashed... It looked like it was forced somehow into gear. Anyway, we managed to glue it together and reassemble it again. It works fine. I hope it will hold while I get the replacement. Inside this assembly, there is also a magnetic switch that accomplishes the electronic signaling while on manual mode. The engineer I was working with said it was beautiful - haha. Engineers ... Thank you again for your attention.
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: MINI Cooper - Shift Cable Replacement
Nick at Pelican Parts 11-04-2015 05:10 PM
any time. Thanks for sharing your installation process and experience. These type of comments add so much to the Pelican tech community.
- Nick
