-   MINI Discussion Forum (http://forums.pelicanparts.com/mini-discussion-forum/)
-   -   Question on Clutch Master and Slave Cylinder Replacement (http://forums.pelicanparts.com/mini-discussion-forum/891698-question-clutch-master-slave-cylinder-replacement.html)
BADGER (guest) 11-19-2015 05:14 AM
IVE JUST FITTED A NEW CLUTCH AND ON BLEEDING IT WITH AN ELETRTRONIC BLEEDER IT WAS OK WITH PRESSURE ON.BUT AS SOON AS I TURNED OF PRESSURE I LOSE THE PEDAL AGAIN.TRYED NEW SLAVE AND MASTER CYCLINDER.CA ANYONE HELP ME PLEASE.02 MINI COOPER S
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: MINI Cooper - Clutch Master and Slave Cylinder Replacement
Nick at Pelican Parts 11-19-2015 05:14 AM
The slave cylinder probably isn't being bled. Use your bleeding tool, once the system is air free, try to manually bleed the system. Help the slave extend by pushing the clutch fork, this may help.
- Nick
