-   MINI Discussion Forum (http://forums.pelicanparts.com/mini-discussion-forum/)
-   -   Question on Clutch Master and Slave Cylinder Replacement (http://forums.pelicanparts.com/mini-discussion-forum/891700-question-clutch-master-slave-cylinder-replacement.html)
RUIV (guest) 11-19-2015 04:15 AM
2002 mini cooper-s:sometimes problems to get the first gear...I had to move the car a little in second,stop and then the first will go easy.Advised to get a new slave clutch and the boot on old one when pushed,a lot of oil came out.With new one on I can put gears when the car is off.Soon I turn the key and start the car ,can't get any gears.Can you give me your opinion and advice?Thank you very much.
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: MINI Cooper - Clutch Master and Slave Cylinder Replacement
Nick at Pelican Parts 11-19-2015 04:15 AM
The hydraulic system may need to be bled again. The slave cylinder probably isn't being bled. Use your bleeding tool, once the system is air free, try to manually bleed the system. Help the slave extend by pushing the clutch fork, this may help.
- Nick
