-   MINI Discussion Forum (http://forums.pelicanparts.com/mini-discussion-forum/)
-   -   Question on Subframe Removal (http://forums.pelicanparts.com/mini-discussion-forum/891703-question-subframe-removal.html)
XCoach (guest) 11-19-2015 05:18 AM
Why is it necessary to remove the drive shafts to drop the sub frame? I have my front shocks off to install new ones and was going to drop the frame to install new bushings and ball joints and a larger sway bar...But I don't understand what the drive axles could be interfering with. Please help!
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: MINI Cooper - Subframe Removal
Nick at Pelican Parts 11-19-2015 05:18 AM
Because the motor and trans remain attached to the vehicle body, using an engine support. The subframe can't come down with the axles attached.
- Nick
