-   MINI Discussion Forum (http://forums.pelicanparts.com/mini-discussion-forum/)
-   -   Question on Draining Filling Cooling System (http://forums.pelicanparts.com/mini-discussion-forum/893169-question-draining-filling-cooling-system.html)
David (guest) 11-30-2015 07:32 AM
Hello Pelican parts, I'm very thankful for your technical articles. They are very informative. I was changing the turbo on my 2007 R56 mini and now that I'm completely done, I need to fill the coolant back up. Your article talks about bleeding the air out of the system but it doesn't show the location of the bleeder valve. Can you tell me where it is located? Thanks, David.
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article - Mini R56 - Draining Filling Cooling System
Nick at Pelican Parts 11-30-2015 07:32 AM
Some models have a bleeder on the thermostat, at the top. Others do not. You can bleed by filling the system as described in the article.
- Nick
