-   MINI Discussion Forum (http://forums.pelicanparts.com/mini-discussion-forum/)
-   -   Question on Automatic Transmission Fluid Change (http://forums.pelicanparts.com/mini-discussion-forum/897394-question-automatic-transmission-fluid-change.html)
sweepback (guest) 01-05-2016 07:38 AM
Do I need replace filter?
I think it is metal mesh, So, Is it possible reuse after cleaning?
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: MINI Cooper - Automatic Transmission Fluid Change
Nick at Pelican Parts 01-05-2016 07:38 AM
If you remove it, replace it. The seal will be worn and may not seal correctly again.
- Nick
