Hi, I got P0108 code for the MAP sensor. I replaced the sensor and cleared the code. When I start the car, turn off, and restart, the code comes back again. any ideas? thank you
__________________ This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article - Mini R56 - Turbocharged Engine Pressure Sensor Replacement |
Check the wiring for the sensor to the DME. Also be sure you replaced the right sensor.
- Nick |
| All times are GMT -8. The time now is 04:48 PM. |
