Do you have a article for transmission fluid change for 2008 mini cooper s automatic engine or R56 mini cooper s Automatic?
__________________ This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: MINI Cooper - Automatic Transmission Fluid Change |
The article you commented on should cover your vehicle:
http://www.pelicanparts.com/techarticles/MINI/28-TRANS-Automatic_Transmission_Fluid_Change/28-TRANS-Automatic_Transmission_Fluid_Change.htm if not, I would grab a repair manual. It will have the procedure, special tools and torque specs. Give our parts specialists a call at 1-888-280-7799. - Nick |
| All times are GMT -8. The time now is 04:30 AM. |
