-   MINI Discussion Forum (http://forums.pelicanparts.com/mini-discussion-forum/)
-   -   Question on Brake Pad Sensor Testing (http://forums.pelicanparts.com/mini-discussion-forum/901510-question-brake-pad-sensor-testing.html)
jordan leavitt (guest) 02-06-2016 12:10 PM
I really like how you said that, "When the brake pedal is pressed, brake fluid is forced out of the brake master cylinder and through the brake lines to each brake caliper." I had no idea that we needed to check our brake fluids for this reason. The other day my breaks went out and it turned out that I was out of brake fluid. What causes my brake fluid to run out?
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article - Mini R56 - Brake Pad Sensor Testing
Nick at Pelican Parts 02-06-2016 12:10 PM
You may have a fluid leak.
- Nick
