-   MINI Discussion Forum (http://forums.pelicanparts.com/mini-discussion-forum/)
-   -   Question on Camshaft Position Sensor Testing (http://forums.pelicanparts.com/mini-discussion-forum/901513-question-camshaft-position-sensor-testing.html)
Gabriel (guest) 02-06-2016 12:11 PM
Fault code 2968, Inlet camshaft sensor. I complied with your troubleshooting guide above. Great help. I have 5VDC going in to pin 1, 12 volts to 0 as the engine rotates on pin 2 and a good ground on pin 3. The only thing i need now is to know wether or not the ECU is seeing that signal from the hall effect sensor. I ordered a repair manual from ebay but havent received it yet. Dealer claims car is out of timing, but you would have miss for codes along with it no?? Any idea what pin/s i should check on the ECU for continuity from the wires off the crankshaft sensor. Thanks for the help.
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article - Mini R56 - Camshaft Position Sensor Testing
Nick at Pelican Parts 02-06-2016 12:11 PM
Just locate the terminal at the DME and check for the same voltage as you have at the sensor. That or run new wires. Ohms is not a good test for wiring, as it is not dynamic.
- Nick
