-   MINI Discussion Forum (http://forums.pelicanparts.com/mini-discussion-forum/)
-   -   Cruise control malfunction CEL (http://forums.pelicanparts.com/mini-discussion-forum/901676-cruise-control-malfunction-cel.html)
David Floyd 02-07-2016 10:56 PM
First start up after timing chain death rattle repair, fired right up nice and quiet feeling relieved.
Let it idle for a few minutes and CEL popped up engine half yellow and cruise control malfunction,engine will not rev up.
Also changed the turbo oil feed/drain lines and new plugs during repairs.
Any ideas on what's causing the CEL ?
2010 Cooper S
Luccia at Pelican Parts 02-29-2016 02:55 PM
Hello David - did you get this issue resolved? Engine half yellow is a reduced engine power warning and it sounds like it went into limp mode. Do you have a code reader to plug into the OBDII port to get the code that is triggering your light?
