-   MINI Discussion Forum (http://forums.pelicanparts.com/mini-discussion-forum/)
-   -   Question on Control Arm Bushing and ball joint Replacement (http://forums.pelicanparts.com/mini-discussion-forum/902529-question-control-arm-bushing-ball-joint-replacement.html)
Lindsay (guest) 02-15-2016 05:34 AM
I have a 2003 mini cooper s. We are trying to get the control arm into the bushing and are having so many issues. It is below freezing outside and I think the rubber is supper hard making it harder to get in. Do you have any suggestions. This job has been a nightmare and we are almost done. This is the last obstacle to get over. Please.
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: MINI Cooper - Control Arm Bushing and Ball Joint Replacement
Nick at Pelican Parts 02-15-2016 05:34 AM
Try lubricating it with dish soap.
- Nick
Dave at Pelican Parts 02-15-2016 09:09 AM
That should work as a lube, as should glycerin. Which you can find at the drug store. You can soften the rubber by dunking it in simmering water for a couple of minutes as well, but if the weather is really cold out you will have to hurry to get it installed before it cools off too much. I know of people using camp stoves in their garage to heat water for making bushings pliable. (Make sure your garage is well-vented if you try this!!)
--DD
