If you want to get more clearance to get the reinforcement plate into position remove the top nuts and have both struts hang down at the same time. Once you use the floor jack to lower the second side the tension on the sway bar will be released and it will stop holding up the other side and instead provide weight that will bring both control arms and struts down.
__________________ This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: MINI Cooper - Strut Tower Reinforcement Plate Install |
Thanks for the additional info. We appreciate it.
- Nick |
| All times are GMT -8. The time now is 01:07 AM. |
