Some info on how to disconnect the electrical plugs from the sensors would be nice, there seem to be hundreds of different ones used and they are awfully easy to screw up. The plug for the temp sensor is particularly frustrating, as it is so crammed in that you cannot see both sides of the plug to figure out how to release it without damage.
__________________ This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article - Mini R56 - Coolant Temperature and Oil Pressure Sensor Replacement |
FOllow the steps until you reach each sensor. The directions on how to release the connector is in the text description next to the sensor.
- Nick |
| All times are GMT -8. The time now is 02:48 AM. |
