-   MINI Discussion Forum (http://forums.pelicanparts.com/mini-discussion-forum/)
-   -   2005 A/T question (http://forums.pelicanparts.com/mini-discussion-forum/904448-2005-t-question.html)
speedman 03-01-2016 11:37 AM
2005 A/T question
Does anyone know if the 6 speed A/T in my cooper S can be made to stop hard shifting after it is warmed up. Is this something I must live with or can stuff be added to make it better
speedman 03-01-2016 11:38 AM
how about adding a drain plug to the pan and changing the fluid a bunch of times or adding an external cooler
Luccia at Pelican Parts 03-03-2016 03:45 PM
Have you checked the fluid level? If the level is good it could be that the fluid in your transmission is breaking down once it warms up. A lot of MINI drivers actually like running Red Line transmission fluid. Have you ever replaced the fluid? We have a lot of great info about the fluid change for the 6 speed Agitronic transmission here: Pelican Technical Article: MINI Cooper - Automatic Transmission Fluid Change
Red Line fluid for your transmission is D4 ATF here: Pelican Parts.com - Red Line D4 Automatic Transmission Fluid and don't forget the filter here: http://www.pelicanparts.com/catalog/SuperCat/6319/MIN_6319_TRAUTO_pg1.htm#item3
Try that out and see if it makes a difference. Let me know what you find out.
