Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
Question on Engine oil Burning
Hi I own a 2007 R56-S 114k miles. with the following mods.
Handling:
Koni FSDs - Alta 22mm Rear Sway Bar -
Michelin Pilot Sport A/S 3 (Installed on 10/17/2015)
Go Fast:
K&N Typhoon Intake -
Alta Hot Side Boost Tube -
WMW Turbo Blanket -
WMW Stainless Turbo Lines -
CNT Catless Downpipe -
CNT Catback Exhaust -
Manic Motorsports Stage 2 Tune, set in mode 2 -
NGK 1422 ILKR8E6 Plugs
Maintenance Items:
De-carboned/Walnut Blasted the intake valves in 8/15
Replaced Oil Cooler and O-Rings 11/14
Oil/Filter always changed with Mobil 1 0w-40 and NAPA Gold filter.
Replaced the Valve Cover and Gasket in 8/15
NAPA 7547 Battery installed 2/15
I recently have noticed that i am burning engine oil....i get a small amount of dark exhaust in 1st and 2nd gear... and i have to add a bit of oil during the interval period.
Any thoughts ideas?
Old 03-06-2016, 07:15 AM
Administrator
Luccia at Pelican Parts's Avatar
Hello!
MINI's are known to consume oil. How much oil are you consuming every 1000 miles? Is the dark smoke while driving at normal speeds/acceleration or is it when you're accelerating quickly?
Old 03-07-2016, 02:30 PM
