-   MINI Discussion Forum (http://forums.pelicanparts.com/mini-discussion-forum/)
-   -   Question on Turbocharged Engine Timing Chain Guides Replacement (http://forums.pelicanparts.com/mini-discussion-forum/905490-question-turbocharged-engine-timing-chain-guides-replacement.html)
Allen (guest) 03-09-2016 11:58 AM
Is this process only recommended if you have had some mechanical training? I have had almost no experience with engines but the process doesn't look impossible. I also don't want to spend 1700 taking it to a mechanic. Thanks
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article - Mini R56 - Turbocharged Engine Timing Chain Guides Replacement
Nick at Pelican Parts 03-09-2016 11:58 AM
If you are mechanically inclined, you should be able to perform the task.
- Nick
