 I have a 2005 MINI Cooper S. Clutch was slipping, so replaced disc, plate, and release bearing with Luk Kit. Also replaced shift cables. Everything worked great for less than a week. Then shifting became stiff and then impossible to change gears with engine running. Traced the problem to the clutch not disengaging. Replaced slave and master cylinder and that didn't solve the problem. Have bled the system using the method described above. Any possible fixes I should try that don't involve getting back inside the transmission? __________________ This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: MINI Cooper - Clutch Master and Slave Cylinder Replacement |
 If the hydraulics are working, I would assume something inside it faulty. No way around inspecting those items.  - Nick |
| All times are GMT -8. The time now is 09:01 PM. |
