-   MINI Discussion Forum (http://forums.pelicanparts.com/mini-discussion-forum/)
-   -   Question on Automatic Transmission Fluid Change (http://forums.pelicanparts.com/mini-discussion-forum/907346-question-automatic-transmission-fluid-change.html)
bluebird (guest) 03-23-2016 11:01 AM
Need a little he here. Buying a 2004 mini base model with auto trans seller states that there is a trans leak of unknown source which leaves a "spot" on the floor overnight. Has anybody attempted to rig a pump to add fluid via the drain plug. It seems that if the trans was up to temp and the new fliuld up to temp that I could add fluid through the level tube using a syringe of some type. Why not?
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: MINI Cooper - Automatic Transmission Fluid Change
Nick at Pelican Parts 03-23-2016 11:01 AM
I have not tried that.
I opened a post in our forums. A Pelican community member may be able to answer your question.
- Nick
