-   MINI Discussion Forum (http://forums.pelicanparts.com/mini-discussion-forum/)
-   -   Question on Brake Pad Replacement (http://forums.pelicanparts.com/mini-discussion-forum/910426-question-brake-pad-replacement.html)
njjjjh (guest) 04-15-2016 11:45 AM
How many brake pad sensors are on my 2007 Mini hatchback?
Ordered and received pads but forgot about sensors duh!
This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper Brake Pad Replacement (R50/R52/R53 2001-2006) | Pelican Parts DIY Maintenance Article
Nick at Pelican Parts 04-15-2016 11:45 AM
two sensors. One front, one rear. Give our parts specialists a call at 1-888-280-7799. They can figure out what part or repair kit you need.
- Nick
Dave at Pelican Parts 04-15-2016 02:03 PM
If your 2007 is like my 2012, it has one in the left-front brake and one at the right-rear.
I was able to use a pair of vise-grip pliers with the jaws sprung open to twist the piston back into the rear caliper. It was not the easiest thing, but it did work.
--DD
Luccia at Pelican Parts 04-15-2016 02:05 PM
Brake pad sensors for your '07 base cooper are here: Brake Pad Sensors. :)
DIY and info about your pads/rotors in our R56 articles HERE under "Brakes."
