-   MINI Discussion Forum (http://forums.pelicanparts.com/mini-discussion-forum/)
-   -   Question on Thermostat Replacement (http://forums.pelicanparts.com/mini-discussion-forum/911272-question-thermostat-replacement.html)
Kongfish (guest) 04-21-2016 11:10 AM
Nick,
Where on a 2007 Mini Cooper S 2-Door hatchback hardtop, is that Coolant Bleeder valve located a Time? I've looked multiple tutorials posted by Pelican but, I yet to see a photo of a 2007 2-Door Hatchback S showing the correct location of that bleeder valve. Do you have a photo of its location.?
This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper Radiator, Thermostat and Hose Replacement (R50/R52/R53 2001-2006) | Pelican Parts DIY Maintenance Article
Nick at Pelican Parts 04-21-2016 11:10 AM
It depends if the thermostat installed has one. Look down past the cylinder head, toward the thermostat, id present, you will see the plastic bolt with an X for a flathead screwdriver. Loosen it.
- Nick
