-   MINI Discussion Forum (http://forums.pelicanparts.com/mini-discussion-forum/)
-   -   Question on Window Regulator Replacement (http://forums.pelicanparts.com/mini-discussion-forum/911274-question-window-regulator-replacement.html)
Rudd Jr (guest) 04-21-2016 11:11 AM
"from" the gap.. Btw, any idea on how to tightened up the dashboard? Sounds rattling as the were loose screws or clips.. The rattling sounds silenced when i pressed the dashbord.. Just above the center meter console..
This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper Window Regulator Replacement (R50/R52/R53 2001-2006) | Pelican Parts DIY Maintenance Article
Nick at Pelican Parts 04-21-2016 11:11 AM
You will have to find the source of the rattle. it could be as simple as some felt tape to insulate two plastic pieces.
- Nick
