Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
2007 Mini Cooper s Auto transmission change
My question is which route is easier, lowering the subframe to access the bolts on the transmission pan, or raising the engine and transmission to access the bolts on the transmission pan. The steps for raising the engine and transmission are far fewer than lowering the subframe.
Old 04-13-2016, 05:14 AM
Administrator
Luccia at Pelican Parts's Avatar
Just a little confused and want to make sure I know what you're asking. Are you asking about how to go about removing the transmission from the vehicle or changing the automatic transmission fluid and filter?
Old 04-13-2016, 01:47 PM
Looking to change the transmission fluid, not removing the transmission.
Old 04-14-2016, 04:45 PM
Administrator
Check out page 9 on the PDF file in post #3 at this link here: 6-Speed Automatic DIY ATF Change
If you need tools for the job be sure to check our tools page HERE. Automatic filter and fluid HERE if needed.
Old 04-15-2016, 01:55 PM
Luccia, I have a leaking transmission pan gasket that I have to remove. In order to remove, there are bolts that are inaccessible due to the subframe. There are two procedures available two access these inaccessible bolts. One procedure involved lowering the subframe. The other involved raising the engine and transmission.
My question is which procedure is easier, lowering the subframe or raising the engine.
Old 04-22-2016, 04:22 AM
Administrator
I'd possibly think it may be easier to access what is needed by loosing the engine mounts a little and raising the engine. You can take a look at our engine mount articles for some assistance. You loosen the bolts on the mounts to the body and then gently lift on the engine lift point. Don't over lift.
http://www.pelicanparts.com/techarticles/MINI_R56/MINI_Cooper_R56_Tech.htm
Old 04-22-2016, 11:52 AM
Thanks Luccia. I will go that route and let you know how it works.
Litespeed22
Old 04-23-2016, 05:34 PM
