Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
Administrator
Luccia at Pelican Parts's Avatar
R50/R52/R53 Aero Grille Upgrade!
One of the most common front grille upgrades for the first gen MINI Cooper and Cooper S is upgrading the upper radiator grille and lower bumper grille to the factory JCW aero grille.
For install instructions CLICK HERE.
The upper grille section is HERE. The lower grille section on the bumper is HERE.
NOTE: The lower aero grille section on the bumper will require modification for non aero bumpers. You'll need a dremel tool to help with this modification. If you need any tools be sure to check out our tools page HERE. Once you do this modification to the lower grille section it should sit flush.
Old 05-11-2016, 02:01 PM
