-   MINI Discussion Forum (http://forums.pelicanparts.com/mini-discussion-forum/)
-   -   Question on VANOS Solenoid Replacing (http://forums.pelicanparts.com/mini-discussion-forum/913280-question-vanos-solenoid-replacing.html)
Caveman (guest) 05-07-2016 07:06 AM
I RNR My timing chain kit in my 09 Mini Cooper thru the int retard code then the exe retard code I removed and cleaned both Vanos solonoids reinstalled them before this it ran great except throwing codes after I reinstalled solonoids it ran terrible wouldn't idle had a miss up to 3000 RPM could l have an air bubble in a solonoids or ? Where do I go from here
This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper R56 VANOS Solenoid Replacement (2007-2011) | Pelican Parts DIY Maintenance Article
Nick at Pelican Parts 05-07-2016 07:06 AM
You can't have air. I would confirm the timing is correct before you go too far.
- Nick
Dfitz21 05-10-2016 06:06 PM
Did you use the timing tools to setup the camshafts? What codes did you have after replacement? Timing is critical as is the teeth on the crankshaft gear, the replacement of the timing chain tensioner and the guides. Are they all in spec?
