-   MINI Discussion Forum (http://forums.pelicanparts.com/mini-discussion-forum/)
-   -   Question on Front Brake Pad Replacement (http://forums.pelicanparts.com/mini-discussion-forum/913283-question-front-brake-pad-replacement.html)
jkb (guest) 05-07-2016 07:09 AM
There are 2 guide bolts. One has a rubber-like material about 5 mm long that fits in a groove on the end of the bolt. Does this go in the upper or lower position in the carrier? What is purpose of the rubber cushion?
This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper Front Brake Pad Replacement (R56 2007-2013) | Pelican Parts DIY Maintenance Article
Nick at Pelican Parts 05-07-2016 07:09 AM
The rubber insulated pin should be at the top. It is to reduce noise.
- Nick
Dfitz21 05-10-2016 06:02 PM
The rubber cushion is also to insulate the sliders. I would clean them and fill it with a synthetic brake slider grease so they continue to function.
