Could I disconnect the clips from inside of the fender by pressing each plastic bolt to get them free from the holes and avoid break each clip? Then I can re use it since the wheel well arch trim will be out with the clips on it.
__________________ This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper R56 Front and Rear Wheel Well Arch Trim Replacement (2007-2011) | Pelican Parts DIY Maintenance Article |
No. Unfortunately you can't. they need to be replaced every time they are removed.
- Nick |
Wheel arches and wheel arch clips here if needed: Mini Cooper, Cooper S, and Clubman (R55/R56/R57) - Exterior Trim - Page 2
