-   MINI Discussion Forum (http://forums.pelicanparts.com/mini-discussion-forum/)
-   -   Question on Manual Transmission Oil Change (http://forums.pelicanparts.com/mini-discussion-forum/916637-question-manual-transmission-oil-change.html)
Tiv (guest) 06-02-2016 11:26 AM
Hi
I am going to change the gearbox oil in my early 2007 Mini Cooper. Your information above states I could use 75w-80 GL4 which comes up when I input car my details. But in small writing it then states not for use in the cooper with G56-55BG gearbox which I believe I have. One of your reviewers has put the oil into his 2007 cooper. I'm confused, thanks in advance.
This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper Manual Transmission and Differential Fluid Replacement (R50/R52/R53 2001-2006) | Pelican Parts DIY Maintenance Article
Nick at Pelican Parts 06-02-2016 11:26 AM
You will want to confirm what gearbox you have first.
Best bet., Give The Pelican Parts parts specialists a call at 1-888-280-7799. They can figure out what fluid you need.
- Nick
