The notes on figure 27 say to install the timing chain pretensioner tool and tighten it to 0.6NM 5.3 in-lb. Can you recommend an appropriate torque wrench that can be used at this low of a setting. Most small torque wrenches have a working range with a low end around 20 in-lb. I am struggling to find one that is rated for the such a low torque setting.
__________________ This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper R56 Turbocharged Engine Timing Chain Guides Replacement (2007-2011) | Pelican Parts DIY Maintenance Article |
Look for a 1/4 " drive torque wrench. SK, Stahlwille should both make one.
Give The Pelican Parts parts specialists a call at 1-888-280-7799. They can get you one. - Nick |
| All times are GMT -8. The time now is 06:45 PM. |
