-   MINI Discussion Forum (http://forums.pelicanparts.com/mini-discussion-forum/)
-   -   Question on Spark Plugs and Cable Replacement (http://forums.pelicanparts.com/mini-discussion-forum/920670-question-spark-plugs-cable-replacement.html)
unluckiest (guest) 07-05-2016 08:46 AM
Great guide, and a very easy job for a novice mechanic such as myself. That said, it does come with some risks. Started it earlier this evening but then I had one problem: the plug snapped, leaving the thread inside. What do I do? Will a fluted screw extractor do the job, or is a head off task? I'd rather avoid that if possible!
This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper Spark Plug and Cable Replacement (R50/R52/R53 2001-2006) | Pelican Parts DIY Maintenance Article
Nick at Pelican Parts 07-05-2016 08:46 AM
The spark plug snapped off? if that is the case, you will need a specialized extractor to remove it. If the threads stay in, you will need to remove the cylinder head.
- Nick
