-   MINI Discussion Forum (http://forums.pelicanparts.com/mini-discussion-forum/)
-   -   Question on Camshaft Position Sensor Testing (http://forums.pelicanparts.com/mini-discussion-forum/921095-question-camshaft-position-sensor-testing.html)
Ernesto (guest) 07-08-2016 01:48 PM
I'm still getting P0014 and P0015 codes after a timing chain replacement. I double check my timing and still fine. Camshaft Position Sensors are fine as well, Terminal 1 is the sensor supply voltage 5 volts, terminal 3 is the ground for the sensor provided by the DME, and Terminal 3 is the sensor reference voltage / signal wire0 to 12 volts. I also have two new solenoids. What else could be wrong?
This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper R56 Camshaft Position Sensor Replacement (2007-2011) | Pelican Parts DIY Maintenance Article
Nick at Pelican Parts 07-08-2016 01:48 PM
DME. You may have missed something, I would review your tests before condemning the DME.
- Nick
