-   MINI Discussion Forum (http://forums.pelicanparts.com/mini-discussion-forum/)
-   -   Question on Shift Cable Replacement (http://forums.pelicanparts.com/mini-discussion-forum/921619-question-shift-cable-replacement.html)
Kel (guest) 07-13-2016 05:51 AM
Why can't I get 3rd and 5th gear on my 2003 Mini Cooper on the cable ends under the battery can you adjust them. Many thanks Kel
This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper Shift Cable Replacement (R50/R52/R53 2001-2006) | Pelican Parts DIY Maintenance Article
Nick at Pelican Parts 07-13-2016 05:51 AM
Not adjustable, the cables may be worn or you have an internal issue. Try removing the cables and manually shifting the trans into those gears.
- Nick
