-   MINI Discussion Forum (http://forums.pelicanparts.com/mini-discussion-forum/)
-   -   Question on Window Regulator Replacement (http://forums.pelicanparts.com/mini-discussion-forum/924352-question-window-regulator-replacement.html)
learnasigo (guest) 08-05-2016 09:34 AM
Perfect, but need help!! First of all, this article has been perfect! I live more than 3 hours from the nearest dealer and appreciate being able to do this fix myself. After successfully replacing one regulator/motor, I've had a complication. The rear part of the window lowered TOO much and fell off the bottom of the regulator rail. Is there an adjustment to make it stop short of falling off?? I see there are plastic screws associated with the cables on the regulator and am wondering if those could help adjust the cable length so it stops 1/2 inch earlier? Thanks!
This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper Window Regulator Replacement (R50/R52/R53 2001-2006) | Pelican Parts DIY Maintenance Article
Nick at Pelican Parts 08-05-2016 09:34 AM
What year and model are you working on? The regulator should have built in spring loaded stops (most MINis).
- Nick
learnasigo 08-05-2016 06:54 PM
It's a 2003. I was able to get in touch with my old mechanic (when I lived near a mini specialist) and he said the cheaper parts fail, and sometimes quickly. So I'm wondering if I got what I paid for with an aftermarket part....
Luccia at Pelican Parts 09-05-2016 11:01 AM
When purchasing aftermarket parts you definitely want to do your research on the brand. From the ones we have listed on the website I'd recommend going with O.E.M. or Genuine MINI branded window regulators. I wouldn't purchase a URO one personally.
2003 Mini Cooper S Hatchback - Panels & Doors - Page 1
