Will not shift our of D, R56, 2008 S turbo
new trans.. will not shift our of D1. code is P0974 Shift A solenoid High.. cannot find where it is?? can i change it
When i start it .. put in R , it actually JUMPS .. like too much pressure in Tranny we checked both connectors. but it seems that it is not getting signal to shift. .OR Shift A solenoid is saying DO NOT shift out of D1 . or DS says M3 .. will not get out of M3 in DS mode. thanks for any help you can give me. this is just puzzling. |
Did you install the new transmission yourself or did a shop do it? Not too well versed on this code, but maybe see if this info might help you out: P0974 – Shift solenoid (SS) A -control circuit high – OBD2 Trouble Codes
| All times are GMT -8. The time now is 01:48 AM. |
