-   MINI Discussion Forum (http://forums.pelicanparts.com/mini-discussion-forum/)
-   -   Question on Coolant Expansion Tank Replacement (http://forums.pelicanparts.com/mini-discussion-forum/928942-question-coolant-expansion-tank-replacement.html)
Marvin m (guest) 09-14-2016 08:53 AM
17-12-2-754-231-BOE
Hose to expansion tank to radiator,
Im replacing my expansion tank due to the expansion being plastic and not very sturdy i bought the tank and the hose to the radiator, how do you install that?
This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper Coolant Expansion Tank Replacement (R50/R52/R53 2001-2006) | Pelican Parts DIY Maintenance Article
Nick at Pelican Parts 09-14-2016 08:53 AM
Follow the hose to the other end, disconnect it, then rettach and fill and bleed system.
- Nick
Luccia at Pelican Parts 09-16-2016 08:34 AM
What year and model MINI do you have? You're looking at an article for the first gen MINI, but posted a hose for a second gen MINI.
The coolant expansion tank article you'll want to reference is: MINI Cooper R56 Coolant Expansion Tank Replacement (2007-2011) | Pelican Parts DIY Maintenance Article
Hopefully that'll help you with that part better. If you do have a gen 1 MINI you'll want a different part so let me know.
