Guest
Posts: n/a
After changing the trans oil in my wifes car it would not fully engage gears. Now it seems as if it is stuck in neutral. I can start the car and put it in gear and release the clutch and the car doesn't stall, but the pedal returns and doesn't stay at the floor. I don't think it is the clutch but wouldn't the pedal stay at the floor if the slave were gone
__________________ This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper Clutch Master and Slave Cylinder Replacement (R50/R52/R53 2001-2006) | Pelican Parts DIY Maintenance Article |
Pedal may not stay on floor, there may be enough line pressure to help it return.
- Nick |
Administrator
Slave cylinder here if needed: Mini Cooper & Cooper S (R50/R52/R53) - Clutch & Flywheel - Page 4.
