-   MINI Discussion Forum (http://forums.pelicanparts.com/mini-discussion-forum/)
-   -   Question on Manual Transmission Oil Change (http://forums.pelicanparts.com/mini-discussion-forum/929028-question-manual-transmission-oil-change.html)
Naazyd (guest) 09-15-2016 06:09 AM
Hi. I have a 2006 cooper s convertible with automatic transmission. Once my car is heated up the car battles to change gears, the revs peak past 4 then it changes hard with a bang. Do you suggest gearbox oil or buy a complete near gearbox?
Warm regards
This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper Manual Transmission and Differential Fluid Replacement (R50/R52/R53 2001-2006) | Pelican Parts DIY Maintenance Article
Nick at Pelican Parts 09-15-2016 06:09 AM
First check the transmission fluid level to be sure it is correct. Then check the transmission ECM for fault codes. If the system is not working properly, a fault code will be set. This will be your best bet when diagnosing.
- Nick
