-   MINI Discussion Forum (http://forums.pelicanparts.com/mini-discussion-forum/)
-   -   Question on Rear Shock and Spring Replacement (http://forums.pelicanparts.com/mini-discussion-forum/929031-question-rear-shock-spring-replacement.html)
Rui (guest) 09-15-2016 06:13 AM
I'm putting new rear shocks in 2002 mini cooper-s but can't match the lower part of the shock with the the frame where the big screw goes.The shock is lower and I tried to lift it with a jack and it didn't work.Any advise how to achieve it?
This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper Rear Shock and Spring Replacement (R50/R52/R53 2001-2006) | Pelican Parts DIY Maintenance Article
Nick at Pelican Parts 09-15-2016 06:13 AM
You should be able to jack the shock up or lever it up to align the hole. Once close, use a large aligning punch to get the holes together.
- Nick
