-   MINI Discussion Forum (http://forums.pelicanparts.com/mini-discussion-forum/)
-   -   Question on Rear Shock and Spring Replacement (http://forums.pelicanparts.com/mini-discussion-forum/930789-question-rear-shock-spring-replacement.html)
Rui (guest) 10-01-2016 05:19 PM
I just replace my rear shocks and I realized you mentioned to tied the top nut with a torque 30nm22ft/lbs but I did it without it and I tied the nut comparing with the way the nut was on the old shock about 1/2 inc down the "piston".My question and I'm afraid it's a dum one is if it is correct or not because if is wrong I have to remove the shocks again from the car and I'm trying to avoid it if I can.I'll appreciated your attention...: thanks.
This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper Rear Shock and Spring Replacement (R50/R52/R53 2001-2006) | Pelican Parts DIY Maintenance Article
Nick at Pelican Parts 10-01-2016 05:19 PM
If you didn't measure torque, I can;t be sure if you got the tightening correct.
- Nick
