-   MINI Discussion Forum (http://forums.pelicanparts.com/mini-discussion-forum/)
-   -   Question on R50 Airbox and Battery Box Removal (http://forums.pelicanparts.com/mini-discussion-forum/930792-question-r50-airbox-battery-box-removal.html)
Andy (guest) 10-01-2016 05:20 PM
Exact same problem as David. Top left bolt in battery tray rusted and spinning, any help other than cutting plastic surrounding it would be greatly appreciated.
This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper R50 Airbox and Battery Box Removal (2001-2006) | Pelican Parts DIY Maintenance Article
Nick at Pelican Parts 10-01-2016 05:20 PM
Sometimes I apply upward pressure when loosening. This can jam the loose nut below in place enough to loosen it. If not, you'll have to cut or break it.
- Nick
Luccia at Pelican Parts 10-03-2016 09:32 AM
If you have to cut it off the battery box tray M6X21 bolts here: Pelican Parts - Torx Bolt With Washer
