-   MINI Discussion Forum (http://forums.pelicanparts.com/mini-discussion-forum/)
-   -   What is this small rubber doughnut (http://forums.pelicanparts.com/mini-discussion-forum/931289-what-small-rubber-doughnut.html)
Caffys Cafe 10-06-2016 09:50 AM
Found this under my daughters 2005 R52, anyone know what it is, it is quite soft rubber marked "mini" on both sides. Has the number "162" on one side ( could be worn ??? On the opposite side). Local parts dept have not got a scooby, but quite a young kid. It's approx 45mm x 40mm tapered in width From approx 10mm in the centre, has a couple of lugs in the inner circumference.
I have a picture if anyone knows how to upload from an iPhone !!!http://forums.pelicanparts.com/uploa...1475773599.jpg
Caffys Cafe 10-06-2016 10:08 AM
Worked out a way to upload picture, download an app resize and email back to yourself😟😟😟there's got to be an easier way
Luccia at Pelican Parts 10-06-2016 11:20 AM
Welcome to the forum! I just need a little more info. About where would you say this fell off from? Under the engine in the front of the car, rear of the car?
Caffys Cafe 10-06-2016 12:25 PM
Luccia under the front sump area but could have bounced maybe.
Luccia at Pelican Parts 10-07-2016 09:15 AM
I must say, usually I've pretty good at finding these parts, but you've stumped me. By any chance do you see any other numbers are it other than 162? I'm wondering if it is some sort of cover that goes on a chassis part. Are you able to get under your MINI and inspect your subframe area?
Caffys Cafe 10-08-2016 01:42 AM
Mystery solved
I took your advice and dropped the front subframe, the nearside control arm/wishbone main bush has broken up this rubber is part of that assembly. Thanks for directing me in the right area (see piccy, time for a celebratory bacon sarnie👍👍👍)
http://forums.pelicanparts.com/uploa...1475916155.jpg
Luccia at Pelican Parts 10-10-2016 09:16 AM
Awesome! Glad you tracked it down. If you need anything else just be sure to let me know. :)
