How to check manual transmission fluid
Hi. I have a Mini Cooper 2005. I was wondering if I can access the bolt needed to just check the Transmission fluid from under the hood? Or will I have to jack my car up to get underneath?
__________________ This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper Manual Transmission and Differential Fluid Replacement (R50/R52/R53 2001-2006) | Pelican Parts DIY Maintenance Article |
No, you have to access from below.
- Nick |
Figure #4 in the tech article shows you where you need to access it under the vehicle.
Transmission fluids if needed: http://www.pelicanparts.com/catalog/SuperCat/MN01/MN01-Transmission-Clutch.htm http://cdn4.pelicanparts.com/techart...mall/pic04.jpg |
You can also remove the reverse light switch on top of the transmission and check the oil.
| All times are GMT -8. The time now is 01:31 PM. |
