-   MINI Discussion Forum (http://forums.pelicanparts.com/mini-discussion-forum/)
-   -   Question on Power Steering Pump Replacement (http://forums.pelicanparts.com/mini-discussion-forum/931653-question-power-steering-pump-replacement.html)
BGD (guest) 10-09-2016 07:37 AM
'02 R53 - replaced original steering pump with a reman Dorman unit. Seemed to work ok, however after a day or so of use, the pump stays on when ignition off which is the same symptom as the original. Question is; what energizes the pump? Does the key on energize the pump? If so, what is the purpose of the yellow wire connected to the alternator? Thanks for your help.
This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper Power Steering Pump Replacement (R50/R52/R53 2001-2006) | Pelican Parts DIY Maintenance Article
Nick at Pelican Parts 10-09-2016 07:37 AM
Your new pump is likely faulty.
See this discussion I had with some folks few years back.
http://tech.bentleypublishers.com/thread.jspa?threadID=34469&start=0&tstart=0
- Nick
Luccia at Pelican Parts 10-10-2016 09:10 AM
Did you check with a dealer to make sure that your P/S pump may have qualified for the recall?
Power steering units - 2002 Mini Cooper S Hatchback - Steering System - Page 1
