-   MINI Discussion Forum (http://forums.pelicanparts.com/mini-discussion-forum/)
-   -   What wore out my Alternator? (http://forums.pelicanparts.com/mini-discussion-forum/931654-what-wore-out-my-alternator.html)
HawnMini 10-09-2016 07:38 AM
Removed new alternator bench tested 8v ..
.. chuncked that now have a. New new one
Any issue that might have fried stock one and
Replacement alt so I don't install third and screw
It up . Original only put out 11v , replacement 8v
is second one a bad build and not a elec. Issue
Don't see any blatently bad wiring . Any ideas?
This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper Alternator Replacement (R50/R52/R53 2001-2006) | Pelican Parts DIY Maintenance Article
Nick at Pelican Parts 10-09-2016 07:38 AM
Nothing usually kills them, they usually wear out.
- Nick
Luccia at Pelican Parts 10-10-2016 08:50 AM
How many miles are on your MINI and is that the original alternator? If so, it's not uncommon for this item to go bad at some point. Just make sure to replace with the correct one. I'm a bit confused about what you wrote. Are you saying that you're now having an issue with the new one you installed?
Alternators - Mini Cooper & Cooper S (R50/R52/R53) - Charging System & Battery - Page 1
HawnMini 10-10-2016 09:03 AM
- Nick
The new one was bad from the box was just
Worried that there might be a elec. Issue which
Could fry it, so thanks nick I will install.and
The mini has 30k on it
