-   MINI Discussion Forum (http://forums.pelicanparts.com/mini-discussion-forum/)
-   -   Question on Fuel Rail Pressure Sensor Replacement (http://forums.pelicanparts.com/mini-discussion-forum/931671-question-fuel-rail-pressure-sensor-replacement.html)
Matt (guest) 10-09-2016 09:14 AM
Hello I have an 08'mini cooper 1.4L. I ran over a tire just the tread and it shut my car off and wont start. It has no fuel pressure.I check the relay and its ok. It's not leaking any fulid and no wires hanging down.Any help wouldbe great
This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper R56 Fuel Rail Pressure Sensor Replacement (2007-2011) | Pelican Parts DIY Maintenance Article
Nick at Pelican Parts 10-09-2016 09:14 AM
Check the fuel pump fuse and relay. If Ok, possibly damaged to the fuel tank. I don't have the wiring for non-us models, so I can;t be more specific.
- Nick
Luccia at Pelican Parts 10-10-2016 09:22 AM
Definitely could be a relay that worked itself loose. Are there any faults present in the system at all? Maybe also check your fuel pump. You can test it here: MINI Cooper R56 Fuel Pump Testing (2007-2011) | Pelican Parts DIY Maintenance Article.
